Ford Mondeo SID 206
Posted: 19 May 2022, 07:46
by Canfan
Hello I have test the emulator. https://cartools.lv/Shop/product_info.p ... cts_id=206
The problem I can´t get the ECU authorized.
I have found the sync ED360AB2D4341EC3 but it don´t work.
I habe ask a Ford technikan he says me in that car the immo is in the BCU and ABS stored the own sync in the engine contraol unit.
WinRAR-Archiv (neu).rar
Re: Ford Mondeo SID 206
Posted: 19 May 2022, 11:48
Change ABS_ID in ECU eeprom to actual one (ascii 529115 in your dump now).
Or if testing on the bench, transmit periodically CAN ID 260 with actual data.
example: 260 (8) 48 E0 37 34 30 39 39 31 -> ABS_ID 740991
Last 6 necessary, not full as shown by diagnostic tool.
Posted: 19 May 2022, 17:55
by Frolov
and calculate 2 bytes of checksum?
Posted: 20 May 2022, 13:05
by Canfan
I have write the sync code in the emulator and symulate the ABS the the engine will run a short time than i get the fault U0300 Internal Configuration incorrect is a fault from the BCU
Posted: 23 May 2022, 05:45
by Canfan
The emulator works well by S-Max and Galaxy from 2006 too.
Posted: 27 May 2022, 07:09
by Canfan
The emulator works well by DCM3.5 from a Mondeo, S-Max and Galaxy
