EWS3 emulator DDE7 ?
Posted: 09 Oct 2023, 14:54
by AutoKeyEcu
Is the EWS3 emulator from the store compatible with this BMW control unit:? DDE7 530D 2003 Key metal (Not insertable key)
DDE7 793210 - 0281011224
https://cartools.lv/Shop/product_info.p ... ucts_id=81I've never tried one of these, and I now have a DDE7 on the table for immoOFF
Re: EWS3 emulator DDE7 ?
Posted: 09 Oct 2023, 20:13
yes.
Posted: 11 Oct 2023, 07:20
by AutoKeyEcu
ok, thanks..
Posted: 28 Oct 2023, 09:58
by AutoKeyEcu
The Ecu DDE7 0281011224 is a 530D 2003 manual key, but I think it is CAS2, this control unit works in Canbus, for these cases I need emulated EWS4 Can? or is the EWS3 Ews possible?
I can't find the EWS pin line
, can you help me with the pinout?
micro- MPC556
Ext-Flash AM29BL802cb
EEP. 95320
Posted: 29 Oct 2023, 10:08
EWS3.
Mandatory!
Search WDS for pinout. If I remember right, you need to take attention on pins 7 and 10 in a narrow connector
One is "15", another is CAS_BUS (EWS).
Posted: 03 Nov 2023, 18:16
by AutoKeyEcu
EWS3 emulator works correctly in DDE7, Thanks
Posted: 22 Dec 2023, 13:33
by Rus-bmw
Why do you think it's DDE7? This is DDE5 edc16c1.
Ews3 emulator don’t work with DDE7!
Posted: 22 Dec 2023, 16:13
Неповеришь... Но работает!
