Peugeot 307 2003
Posted: 05 Feb 2014, 17:02
by hackbest
Howdy partner need to vary bsi 120000 Someone I can lend a hand thanks and greetings
Peugeot 307 2003
Re: Peugeot 307 2003
Posted: 05 Feb 2014, 17:40
by Ashot2009
Какой пробег в Вашем дампе ?
Что показывает приборка (думаю 999999)?
Posted: 05 Feb 2014, 22:56
by hackbest
here have already bsi file modificaco 120000km but there is a trick but I can not get to save again this puts the original in tachosoft
Instruction: read the 68HC912DG128 chip from the BSI (Valeo), and
edit the mileage as shown here. Then connect dash to the connectors .
on the car WITHOUT the BSI. Put the key to the ignition, but do not start!!!
just power on the dash. Dash value will self deletes.
After this connect the BSI and km value will be automatically loaded from BSI to dash.
I do not get that record
someone can help me thanks
Posted: 06 Feb 2014, 08:53
by Ashot2009
Нужно делать и приборку
Posted: 06 Feb 2014, 09:24
by hackbest
Hello again anyone know how to reset the dash or trick to record the miles of bsi records in this case but alos removing contact returning originals.
Posted: 06 Feb 2014, 11:51
Если сипмтом, разговор чисто с собой (в одни ворота), как поставить диагноз?
