MBcan, MBir, MBkey, MBnec, MBelv... discussion
Gince
Has thanked: 6 times
Re: MBcan, MBir, MBkey, MBnec, MBelv...
Postby Gince » 12 Mar 2018, 18:40
MB Sprinter 2012 USA 3.0 CDI. I think it's FBS3...
Postby efka » 12 Mar 2018, 19:05
It is FBS3 and I definitely read that module. Check your connections (I hope you are not trying to read it through OBD2 port?)
Gince
Postby Gince » 12 Mar 2018, 19:48
I use this connection, and no communication with MBcan. On the bench of course. EDC17CP10
Postby efka » 12 Mar 2018, 20:00
You did SOMETHING WRONG. I Did read this MS myself.
Gince
Postby Gince » 12 Mar 2018, 20:11
It reads ME9.7 perfect, I can scan CR6P in vehicle with STAR, but on the bench CANtool no response. Wiring OK. Guess no luck
Postby efka » 13 Mar 2018, 06:28
I see that you have marked CRD2 (shall not really matter but its not CRD2 its CR6) .Try 120 Ohm resistor between CAN lines. Could help. I might be able to see that 906 next week and connect to it. But I definitely had this particular MS (US version) done with this tool.
Gince
Postby Gince » 13 Mar 2018, 12:23
I do have terminating resistor connected, I tried with CRD2 / without all options. Strange thing I tried to connect Mercedes STAR on bench to this ECU, can not scan - asks for ignition ON all the time (pin 15 is ignition supplied though). Thank you
Postby efka » 13 Mar 2018, 18:29
Remember we talked how to connect to 7G on 221? On sprinter - right side a pillar next to glovebox - you will find CAN terminator with GREEN wires.... (Not violet - although if your car has DEF-SCR violet also will be there) - connect to that terminator with CAN HI CAN LO and try then (no resistor needed as its in that terminator - it will work.
Gince
Postby Gince » 14 Mar 2018, 14:47
I managed to connect to ECU via can in car. Thank you efka!! So next question - what is needed to connect on bench? I suppose EZS?
Postby efka » 14 Mar 2018, 21:02
Nothing. It must connect . You are missing somethinbin your connections. You are connected now direct as you would on the table.
hamzadaw2000
Been thanked: 1 time
Postby hamzadaw2000 » 05 May 2018, 21:47
Hi,
W204 all keys lost procedure, I have MBir and elv, what other tools need to buy in order to have this function active?
Postby Girts » 27 Sep 2018, 14:05
Так. Давно ничего новенького небыло по теме, верно?
Ну тады...
Решили всё же пустить в массы - OFFLINE KEY CALCULATION
Что требуется -
1) комп с кучей свободного места. 40 гигов на диска С будет в самый раз.
2) хороший интернет, чтоб эти гигабайты скачать
3) желание и надобность.
Для скептиков - это не SKC, тут совсем другие методы используются. Результат - расчитываются все 8 ключей. С вероятностью 99.99%. Естественно при условии, что хэши реальные, а не кем то с потолка придуманные.
Расчёт sonder hash - это так, бонус. Сами удивиляемся, но оно иногда выстреливает.
Что ещё - все собранные средства отправляются на благотворительность.
:crazy:
volly
Has thanked: 136 times
Been thanked: 26 times
Postby volly » 18 Jul 2019, 09:59
Всем привет!Кто нибудь пробовал ключи от XHORSE VVDI BE Key с Mbir,а то надоела игра в рулетку,от ecu sells китай через раз прокатывает,или посоветуйте где понадежней ключи приобрести.Спасибо!
Postby efka » 18 Jul 2019, 11:00
ВВДИ ключи с МБИР неработают. Впрочем как и с многими другими приборами. Ключи качества хорошево ну залоченые под ВВДИ. Имеем пару на тесты от ихних официалов мож на досуге чево то и сострепаем. Кстати тупой обход - имея рабочий БЕ ключ - прописать ево в МБИР, затем (если у вас опция открыта) прочитать епром прогой БЕепром и тупо залить в ВВДИ - у меня так сработало.
Master benz
Has thanked: 397 times
Been thanked: 342 times
Postby Master benz » 18 Jul 2019, 21:36
У меня есть ключи от vvdi и всё отлично работает с MBir и BE .Не давно писал их в 203 кузов. Если интересно могу кинуть ссылку где брал эти ключи
Postby efka » 19 Jul 2019, 02:27
ну давай кидай ссылку на ключи ввди ибо они не ввди так как оригинальные ключи ввди НЕРАБОТАЮТ с мбир - у них даже функция переключения радиоканала при записи по ИР имеетса оригинальным прибором ввди. Мы их брали у официалов - они лежат у Гиртса на растерзание.
Postby Girts » 19 Jul 2019, 02:43
efka wrote:они лежат
Хорошо что напомнил.
Ещё бы вспомнить, куда я их засунул.... И где они ща лежат....
А так, вообще то, на том же ебее попадаются комплектики - замок и два ключа. Примерно за 50 европейских денег. Если спецом покупать те, которые НЕ хром, то вероятность непопастся на голимый китай или BE-образные примерно стопроцентная. ИМХО найболее правильное решение. И всегда доступное, и предложении нестановится меньше, ибо сам хлам уже массово идёт на переплавку в гвозди.
Been thanked: 879 times
Postby Daniulis » 19 Jul 2019, 07:22
Girts wrote: замок и два ключа. Примерно за 50 европейских денег.
Ето что за комплект такой?
Master benz
Postby Master benz » 19 Jul 2019, 07:48
Вот фото ключа. Даже если это и подъёбка то качество ( мне кажется) не плохое. Брал тут
https://rover.ebay.com/rover/0/0/0?mpre ... 1762910551
Master benz
Postby Master benz » 19 Jul 2019, 08:03
Ещё пару фоток. Как подтверждения о работоспособности
Return to “CARTOOLS”
