PCFprog
amgadtoony
Re: PCFprog
Postby amgadtoony » 02 Oct 2017, 19:46
Mr Girts , Mr Solitaire
i make the connection according to MK3 pdf file connectios and used the dumps as i sent to you , so i need a video that describes the steps exactly
with my best regards
solitaire
Has thanked: 51 times
Been thanked: 188 times
Re: PCFprog
Postby solitaire » 03 Oct 2017, 08:11
Why you ask here? Why you not ask file seller?
amgadtoony
Re: PCFprog
Postby amgadtoony » 03 Oct 2017, 09:10
i ask here because i bought my pcfprog programmer from here , and i don't mind to buy the software from you if mine is wrong
Re: PCFprog
Postby efka » 03 Oct 2017, 09:27
Where did you get your files from? That is the question
amgadtoony
Re: PCFprog
Postby amgadtoony » 03 Oct 2017, 15:34
thanks for all i solved the problem i must choose the right eeprom size from setting
don
thanks
Re: PCFprog
Postby Girts » 07 Nov 2017, 14:41
User manual for beginners:
There are some basic rules to avoid key damage.
Keep in mind that "CONFIG" function is intended for advanced users.
  • Install drivers (tested on WIN XP and WIN 7 32BIT)
  • Before working make these settings - set EPROM to 8192 and EEPROM to 1024, then set BOOT MCU in KEY 7945;7952;7953
    Before utilising Erase function make sure you selected proper EPROM and EEPROM selection according to MCU type in the key
  • Some keys use only EEPROM. In that case there will be no EPROM folder avaliable.
  • Make sure you use proper dump files for the key.
Step by step guide
  • disassemble key , remove battery
  • Start software, select "SETTINGS" , choose proper EEPROM size (you can check it in key file folder) , then set correct EPROM size. After that select proper KEY MCU type (45/52/53 or 41/61)
  • Execute "ERASE" function. Sofware will respond with DONE in bottom right corner
  • Select FILE LOAD, choose correct EEPROM dump, push WRITE button. Software will respond with OK
  • Select FILE LOAD, choose correct EPROM dump, push write function. Software will respond with OK.
  • Open "CHIP" and utilise "Protect" function. If procedure executed correctly software will respond with "DONE" in the bottom right corner
Thats IT.
Your Key is ready.
marcin2502
Been thanked: 1 time
Re: PCFprog
Postby marcin2502 » 07 Nov 2017, 15:56
When connecting pcfprog to laptop it does not detect device, in pcf programmer - "no device". I tried to connect to windows xp and windows 10 has some idea to work
Re: PCFprog
Postby Girts » 07 Nov 2017, 16:14
Download and install drivers from FTDI site.
http://www.ftdichip.com/FTDrivers.htm
marcin2502
Re: PCFprog
Postby marcin2502 » 07 Nov 2017, 20:22
Unfortunately the remote device unrecognized. When connected to the notbook ,1 times the orange LED flashes and then no reaction. On windows 10 device information not recognized, windows xp does not detect the device
The drivers on this page work because I am working on an ecu tool that goes to these drivers
marcin2502
Re: PCFprog
Postby marcin2502 » 08 Nov 2017, 21:37
after installing on new clean system windows 7 attempt to run pcf programmer ends with error "can not run program not found FTD2XX.dll"
Been thanked: 879 times
Re: PCFprog
Postby Daniulis » 08 Nov 2017, 21:52
So, did you try to copy file "FTD2XX.dll" in to the parent folder of the software?
marcin2502
Re: PCFprog
Postby marcin2502 » 08 Nov 2017, 22:31
Continue unchanged. Pcfprogrammer starts but does not detect the device. The manager of the device did not appear. Once connected, the device blinks once and blinks. Installed D2XX driver from the link above, I already have ideas come to an end. I currently have a clean windows 7 basic system
Re: PCFprog
Postby Girts » 08 Nov 2017, 23:05
Another PC?
Another cable?
Printscreen from "device manager"?
marcin2502
Re: PCFprog
Postby marcin2502 » 09 Nov 2017, 18:22
Hi, so the case was explained. I installed windows xp with sp3. After connecting the PCFprog the device was installed and working immediately
Re: PCFprog
Postby efka » 09 Nov 2017, 20:45
On your other systems you are missing some frameworks Keep in mind if you have latest frame network it does not mean anything you must have earlier ones too....
rgs
Re: PCFprog
Postby rgs » 14 Dec 2017, 17:10
hello
I have a question after virginise 285974100R_433 remote don t work
thanks for help
Arriazu
Re: PCFprog
Postby Arriazu » 28 Jan 2018, 21:34
Consult, with which equipment can the ID be changed in the PCF79xx?
Thanks
AutoKeyEcu
Has thanked: 35 times
Been thanked: 6 times
Re: PCFprog
Postby AutoKeyEcu » 31 Jan 2018, 09:24
to change the ID in PCF, you need to make binary arimetica,
To be able to do experiments, it is advisable to do this ¡¡¡ viewtopic.php?f=30&t=1807
antuk
Has thanked: 174 times
Been thanked: 123 times
Re: PCFprog
Postby antuk » 19 Feb 2018, 19:42
Hello, френды :)
Хелп ми плиз PCF7953 36 pin connect pinout .
Можно распиновочку подключки ?
Ну если ещё на форд - ваще зацылую :)
Re: PCFprog
Postby Girts » 20 Feb 2018, 02:15
Седьмой пост на первой странице этой темы - некатит?
Return to “CARTOOLS”
