MBkey:
Virtual key: emulates real working key based on KeyID, Password, Initial hash. You must enter key distance too (remaining “life” is based on distance). You can choose how and when distance is updated - for ordinary key it is updated after each authorization.
MB ESL unlock tool
 Tool for ESL unlocking (old type ESL). You need K-line adapter to work with this software, we believe that you already have one at your workshop.
 It is possible to enter hash for opening and erasing manually or it is possible to calculate it (it takes some time, depends on how lucky you are). Hash for open: about 15 minutes, hash for erasing: up to 2 hours average. Use faster PC if possible!
 To get necessary hashes first read ESL. After that you can disconnect it until hash is ready.
 Process you can interrupt by pressing ESC button. If hash isn’t found, press button GET again.
  Like in previous software we operate here with GREEN key file for writing ESL data. It is because really it isn’t possible to read/write entire dump via K-line, only data blocks (hash list) is available for read/ write operations..
MBkey, MBir
MBkey:
MBir:
Some basic postulates:
Frequently asked questions:
   14EC and 15EB, what’s the difference: for car user there is no difference at all, 14EC is SERIES part, 15EB is SPARE part, nothing more. Functionality is the same.
  What is GRAY key and what it is designed for: it is used in factory to personalize EZS. It contains all key final hashes, password and key set data. After successful EZS personalization it converts itself to standard working key. To personalize EZS in such way EZS must be SERIES and NOT activated, activation must be initiated through diagnostic tool.
MBkey
MBir set
EZS reader - designed to read EIS data blocks via IR portal. It is possible to send custom command to EZS too. You must take attention that DATA block meaning is different for various types of EZS, accessible data block count too. Of course, password is not accessible via IR…
HASH list generator: you enter initial hash and get final hash. If “output to file” is in checked state, you will get full key track with all 196608 following hash values.
MB green key:
It’s a virtual service key  for EIS personalization , can act as ordinary “green” key or “gray” key.
Software is suitable for gray key data preparing for MBir to make real GRAY key too or for  ESL personalization.
Hint: for example you got some old EIS from garbage and repaired it. You can leave it in state “not activated”. It is possible to test it in this state and personalize again and again until you “activate” it with working key. After that you can put it somewhere in dark place at your workshop for later use - until car arrives.
When it is necessary, it is possible to personalize this repaired EIS for  exact car in 5 seconds.
Recommendation: always wait for key to finish tasks (this appears on info screen) if you wish to use it on car. But it is always possible to interrupt this process by pressing ESC button in case if key got stuck (usually damaged key or written incorrectly by 3-rd party device programmers).
-> HOME
MBir:
Full set  consists of:
There are no any USB cables included in set, you must find them by yourself (USB mini type B). ZIF socket is not included in set, but available separately for 100 eur.
Supported keys: all known MOTOROLA based versions, all NEC except keyless ones. We understand that it is very popular nowadays  to ask for keyless support, but in reality there are no keys with keyless option available at the 2nd hand market at all. In case if you have 2 ones with the same firmware inside, you can send them to us and most likely we will add them in special release for you.
