2003 Mercedes S350 2155450608 4J74Y
Darren_W
Has thanked: 13 times
Postby Darren_W » 27 Mar 2021, 12:14
Hello Forum.
Looking for some inspiration :)
This 2003 S350 is a none runner there is no communication with EIS but the key does turn.
Not had this part before I know the keys are held in the left MCU is it configuration in the other?
I can't find a good file set to test or compare with maybe someone can help ?
WBR
Re: 2003 Mercedes S350 2155450608 4J74Y
Postby Girts » 27 Mar 2021, 13:27
Read both 908, take known good EIS, copy both.
Dead MCU's is a common problem.
By the way - test donor EIS on the bench first, may be problems with diagnostic tool / gateway is your issue.
Darren_W
Postby Darren_W » 29 Mar 2021, 09:58
Thanks for your reply Girts, was thinking along those lines, it seems a replacement will have to be from over sea and there quiet strong money, the money isn't the problem but waiting to receive a used part in a few weeks which might be no better will sap my energy :) .... :wall: I will suggest the customer gets a replacement.
Are you sure this needs a gateway, the bench diag is a little better than no coms, its coms with problems and same in the car, I'm using terminal 1 diag socket ~ terminal 2 EIS
WBR
