Strange story about PCF7952
Samsara
Has thanked: 4 times
Postby Samsara » 22 Oct 2020, 14:58
Hello.
I ordered 3 Mitsubishi keys PCF7952 434MHz from Aliexpress ( G8D-644M-KEY-E. Model Number: CE1731) , they arrived on friday and i read them with SVCI 2020 Tag tool.
No problem, they are all Mitsubishi precoded and unlocked ,ready to be programmed .
Saturday, i copied 2 Temic 11 for original Piaggio scooter key with same SVCI 2020 Tag tool , i tried them to the scooter and it's OK.
Sunday , i read the Mitsubishi keys and they are all locked as already programmed to a car !
I suspected SVCI have problem, so i read them with and old FVDI but same problem ,all locked !
During Temic reading/programming ,PCF7952 are far from antenna (more than 50 cm).
I don't understand how is this possible.
Has anyone faced this problem before?
It is possible to read/write this PCF7952 with PCF programmer?
Been thanked: 879 times
Re: Strange story about PCF7952
Postby Daniulis » 22 Oct 2020, 17:22
Samsara wrote:It is possible to read/write this PCF7952 with PCF programmer?
Yes it possible with PCF Prog, but you should have correct bin file for renew it
Samsara wrote:Sunday , i read the Mitsubishi keys and they are all locked as already programmed to a car !
Are you sure you have default crypto low, crypto hi when reading those keys?
Samsara wrote:they arrived on friday and i read them with SVCI 2020 Tag tool.
In this case I would recommend to use proper tool to read those keys, like HTpro Hitag2, Tango, and etc.
Postby Girts » 22 Oct 2020, 18:06
Common problem - MMC uses CDP (biphase) instead of Manchester encoding.
Samsara
Postby Samsara » 23 Oct 2020, 11:52
Hello.
Both, thanks for quick reply.
Daniulis wrote:Yes it possible with PCF Prog, but you should have correct bin file for renew
There's files here
MITSUBISHI : G8D-644M / 434MHz https://www.transpondery.com/projects/p ... files.html
But, it's possible to read a new one (for example , original Mitsubishi key) then save file for reuse it?
Daniulis wrote:Are you sure you have default crypto low, crypto hi when reading those keys?
Girts wrote:Common problem - MMC uses CDP (biphase) instead of Manchester encoding
Abrites do not show those choices.
Here screenshots of problem key and original used key.
If i choose Password Mode or Manchester before read PCF ,it automatically switch to Cipher and Biphase .
Daniulis wrote: this case I would recommend to use proper tool to read those keys, like HTpro Hitag2, Tango, and etc.
I use Tag tool occasionally and quite rarely ,not enough for bought original tools ,but PCF Prog is not expensive if i can copy original keys.
Postby Daniulis » 23 Oct 2020, 22:03
You can't copy content of PCF cuz mostly all they are locked, even if the key is virgin. You can only erase it and write new data.
Samsara
Postby Samsara » 24 Oct 2020, 09:25
Ok,thank you.
PCF7952 are used in somes Mitsubishi keys ,i mean different reference part numbers.
They have differents datas or same for all ?
Postby Daniulis » 24 Oct 2020, 16:03
I don't know lad, I'm not Mitsubishi engineer :)
Samsara
Postby Samsara » 25 Oct 2020, 09:28
Unfortunately :cry: :D
I must bought PCF prog to program those PCF7952 then try to start different models of cars.
